Connectivity Issue on ERICSSON BSC (NWI-E Ports 12)
Hello all,
I am experiencing an issue with my ERICSSON BSC. On each port 12 of the NWI-E, both Gb and A links are configured, but all of them are currently down.
  • The physical links appear to be up.
  • From the NWIE, I am able to ping the Gb gateway successfully.
  • However, a traceroute towards the SGSN does not go through (the traceroute doesn’t leave my equipment)
  • The same issue is observed on the second NWI-E.
  • The SGSN address is correctly defined in the routing table.
  • This setup was working properly before.
Could you please advise on what might be causing this issue?
Thank you in advance for your support
Hi, check traceroutes/pings using from keyword (same as source). Get source IPs from same subnetworks as outputs rrapp:apl=gbi;, rrapp:apl=abi;.
traceroute 10.10.10.10 from 10.10.10.11
