Hi all
I am researching the possibility of connecting an Android smartphone to Huawei BBU main control boards.
The boards I am interested in include:
GTMUb / GTMUc
UMPTa / UMPTb
UMPTe / UMPTg / UMPTga
LMPT
My initial goal is to establish a connection and successfully log in to these boards using an Android smartphone. After that, I plan to test whether it is possible to send MML commands and receive responses directly from the phone.
I would appreciate your experience with the following questions:
Have you successfully connected an Android smartphone to a Huawei GTMU or UMPT board?
Which connection method did you use?
USB Type-C to RJ45 Ethernet adapter
LAN to Wi-Fi Bridge / Mini Router
LAN to Bluetooth Gateway
Direct USB Connection
What specific adapter, router, or device model did you use?
What IP configuration and login method were required?
Which BBU model, main control board version, and software release did you test?
Were you able to send MML commands and receive responses directly from your smartphone?
The solution I am particularly interested in is:
Android Smartphone → Wi-Fi / Bluetooth → Compact Portable Device → Ethernet Cable → Huawei GTMU / UMPT Board
I am looking for a compact device that would allow an Android smartphone to connect to different types of Huawei main control boards.
If anyone has tested a similar connection, I would greatly appreciate it if you could share the device model, connection diagram, configuration details, or any relevant technical documentation.
Thank you in advance for your help.
