I am facing zero ENDC traffic on some nodes for a long time.
There are many nodes with zero traffic on every layer.
What configurations do I check or any other solution?
Remember that you need to have comply UEs from operator to get traffic.
Yes. There is traffic on the neighboring sites but not on others.
Can you explain more the issue u have, which vendor are u using, try first check availability to know if the cells are radiating or not, than do a restart if the availability is ok
