Hello Experts
Is there any moshell command to check for event logs on Ericsson DUW ?
Hi, @King, what about lge?
RBS> h lg
lg[abcdefghijklmnopqrstuvwxyz012345678] [-l <input-directory|logfile|zipfile>] [-m <minustime>] [-p <plustime>] [-s <startdate>] [-e <enddate>] [-g <boardgroup>] [-r <mogroup>] [-n <nodefilter>] [-x <XBlog-filter|ESIlog-filter> ] [-b <xb> ] [-d <nrdumps>|<esiGranularity>] [-z] [-tz <hrs>] [<destination-directory>] [|<unix-cmds>]
Fetching and processing of node logs
All options can be combined together, except options "d","w","x","f" which can only be combined with the options "r" and "c".
CPP Log Options:
- 1: Print the list of logs from the node.
- e: Event log (EVENT_LOG.xml). History of MO events.
Thanks
