Hi All,
Is there any way to check in Wireshark if operators is having SA deployment or NSA deployment?
You can look for Reconfiguration message → inside that SCG Conf.
If that shows messages than it shows NSA.
In current Wireshark in RRC Reconfig I didn’t find SCG conf IE.
Does it means SA deployment?
