Changing NRFrequency / GUtranFreqRelation
Hi - I have a 5G NSA baseband where I’m trying to change the NR frequency. I can happily re-create the objects needed however the OS keeps re-creating the ExternalGUtranCell (and other objects) automatically to the old NRFrequency objects.
It warns of dependency scripts handling those objects when editing in MO Browser, and when changing in moshell - after deleting and attempting to re-create, it’s already there again (pointing at the old objects).
Does anyone have guidance on changing the NR frequency objects (and all relations?)
Hi, @BB_UK, in moshell there is an action changeFrequency which changes related objects on the node. For make changes in other nodes it is better to use Cell Management app in ENM.
Thanks @vlr9999 - great. I can only find changeFrequency on the LTE objects. To change the NR one, which object should be targeted?
This is a standalone deployment without ENM so don’t have that luxury!
Yes, you are right, there is no action for NR. My bad.
