Cell Selection, Cell Reselection and Handover are three different mobility procedures
They may look similar because the serving cell can change, but they occur under different conditions and are controlled differently.
① CELL SELECTION
When does it happen?
• When the device is switched on
• After leaving airplane mode
• When no suitable serving cell is available
What happens?
• The UE searches supported frequency bands
• It detects available cells
• It reads essential system information
• It checks whether a cell is suitable
• It camps on the selected cell
Who controls it?
• The UE
Typical state:
• Idle mode
② CELL RESELECTION
• The UE is already camped on a cell
• The UE is in idle or inactive operation
• A more suitable cell or frequency becomes available
What happens?
• The UE measures the serving and neighbouring cells
• It applies broadcast priorities, thresholds and ranking criteria
• It evaluates whether the reselection conditions remain satisfied
• It camps on the new cell
Who controls it?
• The UE, using parameters broadcast by the network
Typical state:
• Idle or inactive mode
③ HANDOVER
• The UE is connected
• An active call or data session is in progress
• The serving cell is weakening or another cell is more appropriate
What happens?
• The UE performs configured measurements
• It sends measurement reports
• The network evaluates the serving and target cells
• The target cell is prepared
• The network commands the UE to move
• The data path is updated
Who controls it?
• The network
Typical state:
• Connected mode
THE SIMPLE DIFFERENCE
Cell Selection:
Find a suitable cell when no serving cell exists.
Cell Reselection:
Change the camped cell while the UE is not actively connected.
Handover:
Move an active connection to another cell with service continuity.
KEY TAKEAWAY
Selection and reselection are primarily UE-driven procedures.
Handover is a network-controlled mobility procedure supported by UE measurements.
The exact criteria, messages and behaviour depend on the radio technology, UE state and network configuration.
Cell Selection, Cell Reselection and Handover are three different mobility procedures.
Linkedin: :backhand_index_pointing_down:
