Can X2 relations be enabled between inter-PLMN sites?
Are these X2 connections between 4G sites and within the same vendor network?
Yes, for 4G sites with different OEMs, can X2 relations still be enabled?
If there’s no issue on the transmission side, you should be able to enable it.
Is it mandatory to enable X2 in this case?
Yes, you’ll need to check the transmission side first.
Ok, Thank You.
