Can we configure 273 PRB in UL for 100 MHz BW?
As per Open RAN we are taking only 51 PRB in UL.
Any suggestions?
Any suggestions?
Not sure about Open RAN implementation, but it is possible to schedule across 273 PRBs in UL for a UE.
We successfully tested this in lab.
You did it using Open RAN studio or by CU/DU or by NSA mode?
I think we can.
And this case issue is more in planning than architecture like Open RAN or monolithic.
We have to ask do we need to assign max PRB of 273?
If you check planning data then you can find in UL there is only 20 MHZ despite of 100 MHz availability.
