Can an UE get detached or throw RLF because of high UL power transmission?
What happens if gNB receives more than expected power from a UE?
Yes, it can, with cause rlcunrecoverableerror or maxrlcretransmissions.
What do you mean here?
Power in Uplink is regulated by alpha and P0onominal 2 values.
Let’s say I fix P0 nominal and I disable power control.
UE will keep sending PHR reports in Uplink.
So gNnodeB will know if it can be scheduled with more data or with less data.
In Uplink I mean.
So there is no way UE can transmit more power than gNB’s expectations?
Or I can’t force UE to do that as well?
In fractional power control in Uplink target SINR is not fixed.
As per my understanding you can’t.
There are two factors in uplink power control:
So the overall result is 1+2 so even if you disabled TPC based power control, open loop will control everything and it will not reach beyond expected power.
I agree!
In open loop case, UE power can be more than gNB expectations, in which case UE will be told to reduce power.
