Best Tools for Comparing Huawei Configuration (CFG) Files
Dear experts,
What are the best ways to compare Huawei configuration (CFG) files?
Are there any tools available to efficiently analyze differences and track changes in values?
Using Omstar.
I previously used Beyond Compare to compare configuration files.
Also through FMA.
Hey, there are several good ways to compare Huawei CFG files depending. Here are some ways to compare Huawei configuration (CFG) files and track changes.
1. Compare way files side by side.
— if you have two config files and you want to see what changed. Use tools Beyound compare, Winmerge or Meld.
2. Use the built-in Huawei command
3. Use a version control system (for tracking over time)
4. Automated tools (for network teams)
— If you use many Huawei devices, you can use tools that do everything automatically, like Oxidized and SolarWinds NCM.
5. Compare specific values only
Hope this will help you.
