Can anybody tell me what is the difference between super flexi vs flexi 1/2 feeder cable?
Also which cable is best for indoor solution?
Hi @Murad_Azizov,
Superflex cable has a barely bigger insertion loss but it’s a lot easier to install.
1/2 flex is thicker (a little bit) and less flexible (on curves), and has a better performance due to loss, its use is recommended on long and straight stretchs.
I wouldn’t recommend none of them on streches longer than 20m for frequencies up to 2,6GHz.
Dear
Thanks a lot for your prompt responses Highly appreciated
