Baseband integration RP6651 RP6672 failed
For intro, we did many Baseband integration BB6630 BB6648 RP6651 using Sw 23.Q2.
We loaded the scripts to the Baseband locally, not via SMRS.
Currently we are facing issue while doing the same method with Sw 25.Q1.
Baseband BB6648 RP6651 RP6672.
Please help and share any info related to this issue.
Thank you in advance.
ERROR Failed when loading configuration files
This is some of the log:
2025/09/03 00:18:33 PHASE    --------------------------- VLAN SCAN END ----------------------------
2025/09/03 00:18:34 INFO     Received RBS Summary File
2025/09/03 00:18:34 INFO     RBS Summary File format is valid for AutoIntegration
2025/09/03 00:18:34 INFO     RBS Summary File provides paths to:
2025/09/03 00:18:34 INFO         siteBasicFile,
2025/09/03 00:18:34 INFO         siteEquipmentFile,
2025/09/03 00:18:34 INFO     Configuration files download: Started
2025/09/03 00:18:34 INFO     Attempting to download files:
2025/09/03 00:18:34 INFO         siteBasicFile: SiteBasic.xml
2025/09/03 00:18:34 INFO         siteEquipmentFile: SiteEquipment.xml
2025/09/03 00:18:34 INFO         from SMRS: \[169.254.2.1:22\] with user: rbs
2025/09/03 00:18:35 INFO     Files successfully downloaded:
2025/09/03 00:18:35 INFO         siteEquipmentFile: SiteEquipment.xml
2025/09/03 00:18:35 INFO         siteBasicFile: SiteBasic.xml
2025/09/03 00:18:35 INFO     Configuration files download: Finished
2025/09/03 00:18:35 PHASE    ------------------------- SOFTWARE DOWNLOAD --------------------------
2025/09/03 00:18:35 INFO     Upgrade package download: Started
2025/09/03 00:18:35 INFO     Downloading upgrade package from path:
2025/09/03 00:18:35 INFO         RadioNode_CXP2010174_2_R27C54_25.Q1
2025/09/03 00:18:35 INFO     Download progress: 0%
2025/09/03 00:18:55 INFO     Download progress: 13%
2025/09/03 00:19:15 INFO     Download progress: 30%
2025/09/03 00:19:35 INFO     Download progress: 51%
2025/09/03 00:19:55 INFO     Download progress: 70%
2025/09/03 00:20:12 INFO     Download progress: 100%
2025/09/03 00:20:12 INFO     Upgrade package download: Finished
2025/09/03 00:20:12 PHASE    ----------------------- SOFTWARE DOWNLOAD END ------------------------
2025/09/03 00:20:12 PHASE    ---------------------- FILE SYSTEM PREPARATION -----------------------
2025/09/03 00:20:12 INFO     Prepare filesystem: Started
2025/09/03 00:20:15 INFO     Prepare filesystem: Finished
2025/09/03 00:20:15 PHASE    -------------------- FILE SYSTEM PREPARATION END ---------------------
2025/09/03 00:20:15 PHASE    ----------------------- SOFTWARE INSTALLATION ------------------------
2025/09/03 00:20:15 INFO     Unpack and install software: Started
2025/09/03 00:20:18 INFO     Checking if Network Loader upgrade is required
2025/09/03 00:20:19 INFO     Network Loader up to date, continuing software installation
2025/09/03 00:20:19 INFO     Preparing upgrade package for installation
2025/09/03 00:20:28 INFO     Checking upgrade package version
2025/09/03 00:20:31 INFO     Upgrade package version: CXP2010174_2-R27C54
2025/09/03 00:20:31 INFO     Software installation progress: 0%
2025/09/03 00:20:51 INFO     Software installation progress: 66%
2025/09/03 00:20:59 INFO     Software installation progress: 100%
2025/09/03 00:21:05 INFO     Unpack and install software: Finished
2025/09/03 00:21:05 PHASE    --------------------- SOFTWARE INSTALLATION END ----------------------
2025/09/03 00:21:05 PHASE    ------------------------------- REBOOT -------------------------------
2025/09/03 00:21:05 INFO     Finish and store log files: Started
2025/09/03 00:21:05 INFO     Finish and store log files: Finished
2025/09/03 00:21:05 INFO     Software installation successful
2025/09/03 00:21:06 INFO     Download completed
2025/09/03 00:21:13 INFO     Integration started
2025/09/03 00:21:16 INFO     Enabling boot on installed software
2025/09/03 00:21:16 INFO     Updating logs
2025/09/03 00:21:16 INFO     Integration will continue after reboot
2025/09/03 00:21:16 PHASE    ----------------------------- REBOOT END -----------------------------
2025/09/03 00:23:06 INFO     Start loading configuration files
Line not shown due to invalid character
2025/09/03 00:23:37 INFO     Start loading configuration files
2025/09/03 00:24:07 INFO     Start loading configuration files
2025/09/03 00:24:37 INFO     Start loading configuration files
2025/09/03 00:24:37 ERROR    Failed when loading configuration files
Hi
This alarm has occurred multiple times in our configuration. The solution was to rename the configuration files using only alphabetic characters, as in the example c.xml.
Thank you very much for the insight.
we will try this.
currently we name the configuration files “SiteBasic_nodeID.xml” and “SiteEquipment_nodeID.xml”
Hi,
We rename the configuration files to :
SiteBasic.xml
SiteEquipment.xml
SiteInstallation.xml
NodeInfo.xml
00_Onsite_RBSSummary_nodeID.xml
We also modified the content of “00_Onsite_RBSSummary_nodeID.xml” to match the new files name.
Still same error message.
Somewhere in your .xml files there is an “invalid character”.
Maybe you can’t see it; for example a white space after an ip address, or an invalid ip address.
Anyways, why trying to comission with the latest software? I still use R50L11 22.Q2 when comissioning, then upgrade the software
Thank you Juan
The same SiteBasic and SiteEquipment XML files are working properly for BB5216 BB6630 BB6648 RP6651 on software 23.Q2.
We tried 24.Q4 and 25.Q1 because RP6672 minimum software is 24.Q3. It’s in the document, and we did commissioning RP6672 with 23.Q2 but failed when installing software.
