I need your support to do the enrollment of LTE baseband to the OSS, kindly support me. I have a script to perform that, but it is always giving some errors.
BR
BR
Hi, @Mani , is it Ericsson, OSS-RC or ENM? Can you share errors?
HI ,
It is Ericsson OSS-RC , I have attached the error for your reference.
BBUTRUSTCETRE_3G> run Enrollment_V4.mos
BBUTRUSTCETRE_3G> st NetconfTls
230503-15:06:26 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
$ssh_pid = 13331
Connected to 10.14.11.15 (SubNetwork=ONRM_ROOT_MO,SubNetwork=GWRNC2,ManagedElement=BBUTRUSTCETRE_3G,ManagedElement=BBUTRUSTCETRE_3G)
Proxy Adm State Op. State MO
10029 0 (LOCKED) SystemFunctions=1,SysM=1,NetconfTls=1
Total: 1 MOs
BBUTRUSTCETRE_3G> st NetconfSsh
230503-15:06:27 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
10028 1 (UNLOCKED) SystemFunctions=1,SysM=1,NetconfSsh=1
Total: 1 MOs
BBUTRUSTCETRE_3G> st CliSsh
10020 1 (UNLOCKED) SystemFunctions=1,SysM=1,CliSsh=1
Total: 1 MOs
BBUTRUSTCETRE_3G> st CliTls
230503-15:06:28 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
10021 0 (LOCKED) SystemFunctions=1,SysM=1,CliTls=1
Total: 1 MOs
BBUTRUSTCETRE_3G> st snmp
10197 1 (UNLOCKED) 1 (ENABLED) SystemFunctions=1,SysM=1,Snmp=1
10198 1 (UNLOCKED) 1 (ENABLED) SystemFunctions=1,SysM=1,Snmp=1,SnmpTargetV2C=1
Total: 2 MOs
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> lget Lm=1$ fingerprint$ > $nodename
MO Attribute Value
Lm=1 fingerprint BBUTRUSTCETRE_3G
Total: 1 MOs
$nodename = BBUTRUSTCETRE_3G
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> set 0 networkManagedElementId BBUTRUSTCETRE_3G
Id MO networkManagedElementId Result
0 ManagedElement=BBUTRUSTCETRE_3G BBUTRUSTCETRE_3G >>> Set.
Total: 1 MOs attempted, 1 MOs set
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> acc NodeCredential=1 cancelEnrollment
Proxy MO Action Nr of Params
9529 SecM=1,CertM=1,NodeCredential=1 cancelEnrollment 0
>>> Return value = true
Total: 1 MOs attempted, 1 MOs actioned
Waiting 5 seconds before starting to poll...
MO ElapsedTime state progressCount progressHeader
NodeCredential=1 0s CANCELLED 100/100 (100%) Action started
Waiting 2 seconds before checking result...
MO ElapsedTime $polp_result $polp_info
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 nodeCredential
230503-15:06:35 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
Id MO nodeCredential Result
9547 SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 >>> Set.
BBUTRUSTCETRE_3G> set SystemFunctions=1,SysM=1,NetconfTls=1 nodeCredential
230503-15:06:36 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
10029 SysM=1,NetconfTls=1 >>> Set.
BBUTRUSTCETRE_3G> del NodeCredential=1
Deleting ...
9529 SystemFunctions=1,SecM=1,CertM=1,NodeCredential=1 >>> Mo deleted
Total: 1 MOs attempted, 1 MOs deleted
BBUTRUSTCETRE_3G> del SystemFunctions=1,SecM=1,CertM=1,EnrollmentServerGroup=1
Deleting ...
9528 SystemFunctions=1,SecM=1,CertM=1,EnrollmentServerGroup=1,EnrollmentServer=1 >>> Mo deleted
9527 SystemFunctions=1,SecM=1,CertM=1,EnrollmentServerGroup=1 >>> Mo deleted
Total: 2 MOs attempted, 2 MOs deleted
BBUTRUSTCETRE_3G> set SystemFunctions=1,SysM=1,NetconfTls=1 trustCategory
Id MO trustCategory Result
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 trustCategory
BBUTRUSTCETRE_3G> del SystemFunctions=1,SecM=1,CertM=1,TrustCategory=1
Deleting ...
Total: 0 MOs attempted, 0 MOs deleted
BBUTRUSTCETRE_3G> del Transport=1,Router=vr_OAM,DnsClient=1
230503-15:06:37 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
Deleting ...
10210 Transport=1,Router=vr_OAM,DnsClient=1 >>> Mo deleted
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> pr trustedcert
Proxy MO
Total: 0 MOs
BBUTRUSTCETRE_3G> get . trustedcert
MO Attribute Value
Total: 0 MOs
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> acc SecM=1,CertM=1 removeTrustedCert
9524 SecM=1,CertM=1 removeTrustedCert 1
Parameter 1 of 1, trustedCert (moRef-RcsCertM.TrustedCertificate):
Enter mo LDN: y
!!!! ERROR: invalid-value. The reference refers to the wrong type of class. Class in model information='TrustedCertificate' class in the supplied DN='ManagedElement'. Attribute name: ManagedElement=BBUTRUSTCETRE_3G,SystemFunctions=1,SecM=1,CertM=1,UNKNOWN.
Total: 1 MOs attempted, 0 MOs actioned
BBUTRUSTCETRE_3G> SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=1
230503-15:06:39 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
coli>SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=1
no such command: SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=1
coli>
BBUTRUSTCETRE_3G>
230503-15:06:40 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
Enter mo LDN: y
BBUTRUSTCETRE_3G> SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=2
coli>SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=2
no such command: SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=2
coli>
BBUTRUSTCETRE_3G>
230503-15:06:41 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
Enter mo LDN: y
BBUTRUSTCETRE_3G> SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=3
coli>SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=3
no such command: SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=3
coli>
BBUTRUSTCETRE_3G>
230503-15:06:42 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
Enter mo LDN: y
BBUTRUSTCETRE_3G> SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=4
coli>SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=4
no such command: SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=4
coli>
BBUTRUSTCETRE_3G>
230503-15:06:43 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
Enter mo LDN: y
BBUTRUSTCETRE_3G> SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=5
230503-15:06:44 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
coli>SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=5
no such command: SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=5
coli>
BBUTRUSTCETRE_3G>
Enter mo LDN: y
BBUTRUSTCETRE_3G> SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=6
230503-15:06:45 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
coli>SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=6
no such command: SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=6
coli>
BBUTRUSTCETRE_3G>
230503-15:06:46 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
Proxy MO
Total: 0 MOs
MO Attribute Value
Total: 0 MOs
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> confb+
BBUTRUSTCETRE_3G> gs+
Perform a get before set = enabled
BBUTRUSTCETRE_3G>
Deleting ...
BBUTRUSTCETRE_3G> cr ManagedElement=1,SystemFunctions=1,SecM=1,CertM=1,NodeCredential=1
Following attributes are optional. Enter attribute value or "d" for default.
Once the MO is created, these attributes cannot be changed (they are restricted).
Attribute 1 of 1, subjectName (derivedRef:RcsCertM.DistinguishedName): CN=BBUTRUSTCETRE_3G
>>> [Proxy ID = 10218] MO name :ManagedElement=BBUTRUSTCETRE_3G,SystemFunctions=1,SecM=1,CertM=1,NodeCredential=1
BBUTRUSTCETRE_3G> $nodename
coli>$nodename
no such command: $nodename
coli>
BBUTRUSTCETRE_3G> cr ManagedElement=1,SystemFunctions=1,SecM=1,CertM=1,EnrollmentAuthority=1
230503-15:06:47 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
ERROR: MO already exists: ManagedElement=BBUTRUSTCETRE_3G,SystemFunctions=1,SecM=1,CertM=1,EnrollmentAuthority=1
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> cr SystemFunctions=1,SecM=1,CertM=1,EnrollmentServerGroup=1
>>> [Proxy ID = 10219] MO name :ManagedElement=BBUTRUSTCETRE_3G,SystemFunctions=1,SecM=1,CertM=1,EnrollmentServerGroup=1
BBUTRUSTCETRE_3G> cr SystemFunctions=1,SecM=1,CertM=1,EnrollmentServerGroup=1,EnrollmentServer=1
230503-15:06:48 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
Attribute 1 of 2, uri (string): http://10.180.100.5:26772/cmp
Attribute 2 of 2, protocol (enumRef:RcsCertM.EnrollmentProtocol):
Enter one of the following integers: 0:SCEP, 1:CMP: 1
>>> [Proxy ID = 10220] MO name :ManagedElement=BBUTRUSTCETRE_3G,SystemFunctions=1,SecM=1,CertM=1,EnrollmentServerGroup=1,EnrollmentServer=1
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> set SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 useTls false
Id MO useTls Result
9547 SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 false --> false -no change-
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 baseDn dc=ldap,dc=mtngb,dc=net,dc=com
Id MO baseDn Result
9547 SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 o=local --> dc=ldap,dc=mtngb,dc=net,dc=com >>> Set.
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 bindDn cn=mtnproxy,ou=proxyagent,ou=com,dc=ldap,dc=mtngb,dc=net,dc=com
Id MO bindDn Result
9547 SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 --> cn=mtnproxy,ou=proxyagent,ou=com,dc=ldap,dc=mtngb,dc=net,dc=com >>> Set.
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 bindPassword cleartext=true,password=mtn@1234
Id MO bindPassword Result
9547 SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 cleartext=true,password= --> mtn@1234 cleartext >>> Set.
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1,EricssonFilter=1 targetBasedAccessControl 0
Id MO targetBasedAccessControl Result
9548 SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1,EricssonFilter=1 0 --> 0 -no change-
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 ldapIpAddress 10.180.100.5
Id MO ldapIpAddress Result
9547 SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 ldap.local --> 10.180.100.5 >>> Set.
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 fallbackLdapIpAddress
230503-15:06:49 10.14.11.15 22.0v MSRBS_NODE_MODEL_20.Q4_480.27915.116_7be5 stopfile=/tmp/10410
Id MO fallbackLdapIpAddress Result
9547 SecM=1,UserManagement=1,LdapAuthenticationMethod=1,Ldap=1 --> -no change-
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,CertM=1,EnrollmentAuthority=1 enrollmentCaFingerprint A8:A9:6E:57:69:70:7D:F5:CF:15:1D:C4:C9:69:5A:7C:54:F8:D0:8F
Id MO enrollmentCaFingerprint Result
9526 SecM=1,CertM=1,EnrollmentAuthority=1 A8:A9:6E:57:69:70:7D:F5:CF:15:1D:C4:C9:69:5A:7C:54:F8:D0:8F --> A8:A9:6E:57:69:70:7D:F5:CF:15:1D:C4:C9:69:5A:7C:54:F8:D0:8F -no change-
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,CertM=1,EnrollmentAuthority=1 enrollmentAuthorityName CN=mtnadm1xNECertCA, OU=ericssonOAM, O=Ericsson
Id MO enrollmentAuthorityName Result
9526 SecM=1,CertM=1,EnrollmentAuthority=1 CN=mtnadm1xNECertCA, OU=ericssonOAM, O=Ericsson --> CN=mtnadm1xNECertCA, OU=ericssonOAM, O=Ericsson -no change-
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,CertM=1,NodeCredential=1 keyinfo RSA_2048
Id MO keyInfo Result
10218 SecM=1,CertM=1,NodeCredential=1 --> 1 >>> Set.
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,CertM=1,NodeCredential=1 renewalmode 1
Id MO renewalMode Result
10218 SecM=1,CertM=1,NodeCredential=1 0 --> 1 >>> Set.
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,CertM=1,NodeCredential=1 enrollmentauthority SystemFunctions=1,SecM=1,CertM=1,EnrollmentAuthority=1
Id MO enrollmentAuthority Result
10218 SecM=1,CertM=1,NodeCredential=1 --> ManagedElement=BBUTRUSTCETRE_3G,SystemFunctions=1,SecM=1,CertM=1,EnrollmentAuthority=1 >>> Set.
BBUTRUSTCETRE_3G> set SystemFunctions=1,SecM=1,CertM=1,NodeCredential=1 enrollmentServerGroup SystemFunctions=1,SecM=1,CertM=1,EnrollmentServerGroup=1
Id MO enrollmentServerGroup Result
10218 SecM=1,CertM=1,NodeCredential=1 --> ManagedElement=BBUTRUSTCETRE_3G,SystemFunctions=1,SecM=1,CertM=1,EnrollmentServerGroup=1 >>> Set.
BBUTRUSTCETRE_3G>
BBUTRUSTCETRE_3G> acc SystemFunctions=1,SecM=1,CertM=1,NodeCredential=1 startOnlineEnrollment
10218 SecM=1,CertM=1,NodeCredential=1 startOnlineEnrollment 1
AT Online enrollment it is showing as received error from the server
BR//
@Mani check this commands:
Looks like you have y between them, remove it.
Enter mo LDN: y
!!! ERROR: invalid-value.BBUTRUSTCETRE_3G> SystemFunctions=1,SecM=1,CertM=1,TrustedCertificate=6
Ok , Thanks , I will perform and let you know.
BR//
Hi,
I did it but another error occurs, do we need to add any parameter in the OSS-RC before any new BB enrollment. If yes kindly share the steps to perform.
Thanks
Hi, @Mani. Enrollment script is all what we need, I believe.
and also the PKI End Entity must be created at the PKI Management in ENM
