For Windows 11, background apps usage control is not easy, below are steps to Disable them from configuration management console.
Disable Background Apps for all users with Group Policy Editor
- Enter gpedit.msc into the Run text box by pressing Win + R.
- Navigate to “Computer Configuration\Administrative Templates\Windows Components\App Privacy”
- Double-click the “Let Windows apps run in the background” policy in the right pane.
- Select the “Disabled” choice, then select “Apply” and “OK.”
For Windows 10 , it was easy.
This is resulting in high data usage if not DISABLED.
