“Hello everyone, I’m currently developing a software to perform zero-touch configuration for Huawei LTE/NR devices.
However, I’m facing a limitation where I can’t access the Huawei element (4G/NR) directly. Instead, I always need to access the U2020 system manually first and then reach the device.
My question is, is there any way to access a Huawei device directly via FTP, SSH, or even through an API using Python?”
You can access to Huawei elements through API of SPG .
Hi Rafael, did you find a solution for integrating U2020 via Python? I’m also looking for one.
