Hello All.
Any counters to find failures in admission control if UE doesn’t support DSS?
Vendors Huawei, Ericsson
Hello All.
If UE doesn’t support DSS then it won’t be configured with DSS.
There are no counters for this.
It’s not about configuring DSS, definitely there will be no DSS configured.
But there will be rejection in admission control with the cause value mapped to DSS not supported.
I do not get your point: if DSS not supported thne DSS will not be configured.
Admission controls are not about DSS.
As per my shallow understanding …
Take NSA case:
If DSS is enabled in a cell and B1 measurement gets succesfull there will be SgNB addition request Reject from gNB as UE doesn’t support DSS.
There may not be subsequent B1 attempts for that particular UE but initial attempt will get rejected.
