Hi all
I have a problem in ab Ericsson baseband 6630 that connected to an air unit 6449b42
The rilink status is enabled but status of air unit is not enabled anyone who knows about it or has same experience please help me
Hi all
any alarms on the BB6630 ?
is GPS OK ?
Hi,
There are a lot of issues that can raise that, rilink UP but no connectivity with AIR.
First i would check if 6499b2 need eCPRI or CPRI, after that i would check if the software installed in the baseband meets the requirements for this(the 6630, like older basebands can be eCPRI or CPRI, not both).
If no mismatch between software used and need for this AIR, check the rilink rate and be sure that used ports from baseband meets the needed rate, check the documentation for higher rate ports on this baseband).
If you use GPS, try to figure out if everything is ok with it(enough satellites viewed and check for LOCKED state in the clockreference). If you use something like 1588v2 8275.1 or 8275.2, try to check the status of the PTP.
If the AIR was connected after the locally commissioning, please check the status of the software from the air, check it by lh list and try to make a lhsh command for software like lmclist or loadnstart.
Br,
GPS is OK and there is no any alarm on bb6630
