Hi ,
here is the link to a useful short video , how to use Device2Device , for analyses of VoLTE, for example.
A question comes to creating and usage possibilities of Multistreams, seems like it can be created only for one basic logfile - at side A and other logfile - at side B , each containing inside a multiple calls or minimum one call per each file. What if we have task to use benchmarking measurements that are recorded in a way that each call is one separate logfile… , can we create a Superstream for calls/files - at side A and create second Superstream for calls/files - at side B and than try to make Multistream of those two Superstreams A and B and create Device2Device (D2D) analysis and create all automatic pre-packaged relevant reports?
Thanks for answer ! P:)
