5G was defined around three usage scenarios: eMBB, mMTC and URLLC. For 6G (IMT-2030), the ITU framework expands this into six usage scenarios, several of which introduce new capabilities rather than simply higher speeds:
1. Immersive Communication: holographic telepresence and multi-sensory XR experiences that extend beyond today’s AR/VR.
2. AI and Communication: AI-native network design, edge intelligence, and semantic communication, which focuses on transmitting meaning instead of raw data.
3. Hyper-Reliable and Low-Latency Communication: applications such as remote surgery, collaborative robotics, and autonomous mobility that require very low latency and very high reliability.
4. Ubiquitous Connectivity: integration of non-terrestrial networks (LEO satellites and HAPS) with terrestrial networks to extend coverage to remote areas, oceans, and disaster zones.
5. Massive Communication: an evolution of mMTC to support denser IoT deployments in smart cities, agriculture, and industry.
6. Integrated Sensing and Communication (ISAC): the network acting as a sensor to support positioning, obstacle detection, and environment awareness.
Among these, ISAC and AI-native design are particularly significant, as they change the role of the network itself rather than only improving performance. However, many of these use cases depend on technologies that are still under research, such as sub-THz communication and an AI-native air interface.
Some questions for discussion:
- Which of these use cases do you expect to become commercially viable first?
- Which ones may take longer due to technical or economic challenges?
- Are there early indications of any of these in 5G-Advanced deployments?
For reference, a short overview of these use cases is available here:
