5G SA Registration & Attach Call Flow — Complete Signaling Journey Explained (UE Power ON → PDU Session)
Ever wondered what actually happens the moment your 5G device powers on and connects to the network? It’s not magic- it’s a beautifully orchestrated sequence of signaling between the UE, gNB, and 5G Core that takes place in milliseconds.
A complete walkthrough covering the entire 5G Standalone (SA) Registration and Attach procedure- from the very first cell search to a fully established PDU session ready for data.
:satellite_antenna: What’s Covered:
Physical Layer & Cell Search
Cell Search → PSS/SSS → PBCH & MIB decoding → SIB1 acquisition
Random Access & RRC Setup
5G Random Access Procedure (MSG1–MSG4) → RRC Connection Establishment
NAS Registration & Security
NAS Registration Request → NGAP Initial UE Message → UE Identity Handling → 5G AKA Authentication → AUSF/UDM interaction → NAS Security Mode Command → Registration Accept/Complete
Session Establishment & Core Interfaces
PDU Session Establishment → AMF, SMF, UPF interaction → N2, N3, N4 interfaces → QoS Flow & DRB setup → GTP-U tunnel establishment → full uplink/downlink data path
:bullseye: Why This Matters
If you’re preparing for telecom interviews, working on 5G Core/RAN protocol testing, doing network troubleshooting, or just trying to actually understand the call flow instead of memorizing acronyms- this breaks the full end-to-end journey into a logical, easy-to-follow sequence instead of scattered spec references.
Most explanations either stop at RRC setup or jump straight into PDU sessions without connecting the dots. This one connects every signaling hop, every interface (N2/N3/N4), and every procedure into one continuous story- the way it actually happens on a live network.
:backhand_index_pointing_down: Watch the full breakdown here:
:link: 5G SA Registration/Attach Call Flow — Complete Walkthrough
What part of the 5G SA attach flow do you find trickiest to explain in interviews- AKA authentication, NGAP signaling, or the PDU session/QoS flow setup? Drop your thoughts below :backhand_index_pointing_down:
