Hi friends,
Not able to access internet with pixel 7. pro connected to 5G SA network.
Ue has successfully registered
Pdu est and pdu resource assignments done.
No internet on device.
Apn settings seem OK.
5G icon with plmn info is visible.
What may be the reason of this issue?
I suspect SMF problems
In pdu estb request accept I dont see challenge handshake authentication protocol info
Thanks
the problem is solved, it is about cs+ps mode of the device. ue tries to initiate vonr bearer first and data after. when disabling cs and ps only mode it worked well…
