5G Protocol Stack - Service Data Adaptation Protocol (SDAP)
:bullseye: 5G NR has introduced a new sublayer, SDAP, in the air-interface protocols stack at both the UE and gNB sides to manage QoS through QoS flows.
:bullseye: The SDAP layer is the topmost L2 sublayer at 5G NR protocol stack SA where gNB connects to 5G Core network.
:bullseye: SDAP is only applicable to the SA option.
:bullseye: SDAP sublayer exists only in the user plane in both gNB and UE.
:bullseye: SDAP interfaces to 5GC UPF using NG-U interface via QoS flows and to the PDCP lower layer via Data Radio Bearers (DRBs).
:bullseye: It is essential role is to map traffic from QoS flows to suitable DRBs.
:bullseye: SDAP layer doesn’t exist in LTE since QoS flows were introduced only in 5G.
:vibration_mode:Functions of SDAP​:mobile_phone_with_arrow:
:sparkle: QoS Management: SDAP enables the mapping of different QoS flows to appropriate data paths. This helps ensure that specific services receive the required bandwidth and latency, enhancing user experience.
:sparkle: Packet Processing: It processes user data packets, allowing for differentiation between various services. It can classify and prioritize packets based on their QoS requirements.
:sparkle: Flow Control: It manages the flow of data by enabling the control of how much data is sent over the network. This is essential for maintaining the performance of high-priority applications.
:sparkle: PDU Session Establishment and Modification: It is involved in the establishment and modification of PDU sessions. PDU sessions are logical connections that carry user data between the UE and the 5G core network.
:sparkle: Support for Multiple QoS Flows: It supports the multiplexing of multiple QoS flows over a single data connection, which is essential for efficiently utilizing network resources.
:sparkle: UPF Interaction: It interacts with the User Plane Function (UPF), which is responsible for processing and forwarding user plane data. SDAP communicates with UPF to convey QoS-related information and ensure proper adaptation.
:sparkle: Interworking with Legacy Systems: SDAP provides mechanisms for interoperability with previous generations of mobile networks (like 4G), facilitating smooth transitions and coexistence in mixed-environment scenarios.
:sparkle: Interaction with N4 Interface: SDAP interacts with the N4 interface, which connects the UPF and the SMF, facilitating the exchange of information related to user plane data handling.
:right_arrow:SDAP Benefits
:check_box_with_check: Enhanced User Experience: By effectively managing QoS, SDAP helps ensure that applications such as video streaming, gaming, and IoT services perform optimally.
:check_box_with_check: Enhanced QoS Management: SDAP enables precise management of QoS flows, ensuring that different types of traffic receive appropriate bandwidth, latency, and reliability based on their specific requirements.
:check_box_with_check: Resource Efficiency: The protocol optimizes the use of network resources, contributing to the overall efficiency and capacity of 5G networks.
