If I’m not mistaken you should be able to see 5G on GUI.
Assuming your Meta/MPSS builds are compliant with 5G, I’d try to deactivate mBN config files.
As last resource, try NV80000 = 64 for SA and 80 for NSA.
I believe, since 5G NR will be associated with LTE as the anchor or NR (SA) at least, there is a possibility that the user may see 5G selection as service(autoselect) and then the handset may be limited to 3 RATs at a time. 5G, and LTE. or maybe 5G, LTE, and WCDMA, if the OEMs are found having manufacturing boundations.
