5G NR Downlink HARQ Demystified
Hi All.
Very nice blog post on: 5G NR Downlink HARQ
While RLC layer uses Automatic Repeat Request (ARQ) retransmission protocol for error detection and correction, MAC layer uses Hybrid ARQ (HARQ) protocol for that purpose.
Source → (Continue reading on LinkedIn): 5G NR Downlink HARQ Demystified
Because in 5G, it’s not just about retransmitting—it’s about smartly managing what to retransmit, when, and how.
Mastering HARQ in 5G NR: Retransmissions, Redundancy Versions & Real-Time Scheduling :repeat::signal_strength:
Understanding HARQ (Hybrid Automatic Repeat reQuest) is critical for grasping 5G reliability and throughput enhancements—but how does it actually work under the hood?
To help decode the complexities, I’m sharing a detailed walkthrough document that explores every corner of 5G HARQ operation—from ACK/NACK messaging to dynamic retransmissions, Redundancy Versions (RV), and how NR differs from LTE.
:blue_book: What’s Inside the Document?
:brain: Transmission-to-Acknowledgement Flow:
Breakdown of HARQ processes through multiple cases—from successful first-pass decoding to multi-step retransmissions using RV = 0, 2, 3, 1.
:gear: Asynchronous Uplink & Downlink in NR:
Unlike LTE where uplink HARQ was synchronous, NR brings flexibility—DCI now carries HARQ process numbers for both UL and DL, enabling independent, out-of-order HARQ operations.
:triangular_ruler: Flexible HARQ Timing with K1 Parameter:
No more rigid 4ms ACK delays! Timing is now dynamically configurable via RRC tables and signaled through DCI, enhancing spectral efficiency in TDD slots.
:bar_chart: Redundancy Versions Explained:
Detailed explanation of how RVs are constructed from circular buffers and how each transmission selects a new RV, improving decoding probability with each attempt.
:dna: Codebook-Based HARQ Bit Construction:
Insights into how HARQ-ACK bits are generated using NR’s more complex, codebook-driven approach—key to interpreting test logs and DCI traces.
:bookmark_tabs: DCI Sample Analysis:
Includes real-world examples of DCI messages showing HARQ process ID, RV index, feedback timing, and more—ideal for anyone analyzing protocol logs or RAN behavior.
:package: HARQ Process Configuration via RRC IEs:
NR allows RRC signaling to define the number of HARQ processors, dynamically tuned to network needs (2, 4, 8, 16). The document includes the exact ASN.1 IE format.
:test_tube: Bonus: Trace Log Sample
A sample Amarisoft trace helps visualize the exact retransmission flow with real-time parameter values.
:inbox_tray: This resource is curated from public domain content, repackaged for clarity and learning. It bridges theory and implementation, helping telecom engineers, testers, and learners decode HARQ in practical contexts.
PDF: :point_down:
5G NR Downlink HARQ Demystified (By Mandeep Jha).pdf (995.5 KB)
