4G LTE vs 5G — What's the Real Difference?
A lot of people think 5G is just faster 4G, but the differences go much deeper-architecture, latency, spectrum, and even the philosophy behind network design. Sharing a breakdown:
1. Speed
  • 4G LTE: Peak speeds around 100 Mbps–1 Gbps (theoretical)
  • 5G: Peak speeds up to 10–20 Gbps (theoretical), especially on mmWave
2. Latency
  • 4G LTE: ~30–50 ms
  • 5G: As low as 1 ms (URLLC use cases)
    This is huge for real-time applications like autonomous vehicles, remote surgery, and industrial automation- 4G simply can’t support these reliably.
3. Network Architecture
  • 4G: EPC (Evolved Packet Core) mostly hardware-based, less flexible
  • 5G: Cloud-native 5G Core (SBA- Service Based Architecture), virtualized, more flexible and scalable
4. Capacity & Device Density
  • 4G: Supports thousands of devices per km²
  • 5G: Supports up to 1 million devices per km² critical for massive IoT deployments
5. Network Slicing
  • 4G: No native support
  • 5G: Built-in- operators can create dedicated virtual networks (eMBB, URLLC, mMTC) on the same physical infrastructure for different use cases
6. Spectrum
  • 4G: Sub-6 GHz mainly
  • 5G: Sub-6 GHz + mmWave (24 GHz and above)- enabling much higher bandwidth but shorter range
Why this matters beyond just numbers:
The real shift isn’t only “faster speed” it’s that 5G’s core is designed to be flexible by default. With SBA network functions talk to each other via APIs instead of being tightly coupled like in EPC. This is what makes things like network slicing possible -operators can spin up a dedicated low-latency slice for a factory, and a separate high-throughput slice for consumers, on the same physical infrastructure. 4G’s architecture simply wasn’t built with that kind of dynamic resource allocation in mind.
Also worth noting: voice handling changed too- 4G relies on VoLTE (falling back to legacy tech in some deployments), while 5G is moving toward VoNR (Voice over New Radio) for a fully native 5G voice path, without depending on 4G/EPC at all.
4G was about better mobile broadband. 5G is about building a flexible, intelligent, slice-able network that can serve completely different types of applications simultaneously-something 4G’s architecture was never designed for.
Would love to hear how others here are seeing 5G SA rollouts handle this in real deployments.
Detailed architecture-focused comparison here, :backhand_index_pointing_right: if useful: LTE vs 5G SA Architecture Comparison"
