Hi Expert,
Do you know if 3G SMS barring can be managed from the RNC side?
I assume it should be handled by the core HLR, but I wanted to check if you have any insights.
Thanks!
Hi Expert,
Thanks!
Just to confirm, yes, it should be handled through the HLR profile, especially if the message is directed toward a specific IMSI.
Absolutely correct - SMS-related barring features are not available for RAN node access.
