3 Vital DWDM Optics Concepts You Should Know
1. TDA (Tributary Disable Action)
TDA is a feature in WDM transponders that defines the action taken when a tributary port is disabled.
Possible actions include:
  • Sending a Local Fault signal
  • Shutting down the laser
  • Transmitting idle frames
A tributary port may be disabled for several reasons, such as:
  • The port being placed in a locked state
  • Hardware faults
  • Fiber or line issues
2. Administrative Status (Admin Status)
Admin status represents the configured state of a port in the NMS (Network Management System).
Common states include:
  • Locked
  • Unlocked
  • Maintenance
This status is manually configurable via the NMS.
  • Locked:
    The port is not in service and does not transmit or receive optical signals.
  • Unlocked:
    The port becomes active and starts emitting optical signals.
3. Operational Status
Operational status reflects the actual ability of the port to carry traffic.
Possible states:
  • Enabled
  • Disabled
This status cannot be manually set; it is only monitored.
  • Enabled:
    The port is functioning correctly and can send/receive traffic.
  • Disabled:
    Indicates a problem that requires troubleshooting.
Basic troubleshooting steps:
  1. Verify the port is unlocked (Admin Status)
  2. Check that the configuration is correct
  3. Inspect for hardware failures
  4. If necessary, perform a warm or cold card reset
  5. Use loopback testing to isolate the root cause
