XML generator for ENM
Hi all,
I am looking for a tool/Macro … to be able to generate xml files to import to ENM, for updating the list of 4G cells parameters.
Any suggestion are appreciated.
Thanks
Grish
@ GrishManouk
As we hope for someone to share something, we can discuss adding this functionality to our tool (bts-ce)
Hi Emmanuel,
That will be grate. I have nstalled the bts-ce, but I have got the error " forbideen page" on trying to access the 192.168…
Regrads
Grish
What version are you running?
Hi, does anyone have any example of script necessary to import into ENM to generate 4G Integration Files? Many Thanks
I hope this python script may help you just keep the ipute file as the CSV file generated from boda bulck parser
looking for your feedback
enmscript.zip (1.7 KB)
