How to check VSWR. In 3G
#1
How to check VSWR in Ericsson 3G
#2
lh ru fui get vswr can measure the vswr of a site
#3
Dear Bunty
This command is valid in P6 version.what about P6 version
#4
What about P6 version
#5
Sorry p7 version bacuse this command is not valid in p7
#6
Omg, Now almost every where is W15B
#7
You can use CABX On RBS to try
#8
How we check VSWR in Ericsson 3G with CABX command pls elaborate.
#9
RBS9100> cabx
170818-17:47:15 10.160.248.137 17.0e RBS_NODE_MODEL_U_4_95 stopfile=/tmp/19407
Please enter Node Password:
Node type: RBS6601W
SMN APN BOARD FAULT OPER MAINT PRODUCTNUMBER REV SERIAL DATE TEMP COREMGR
0 1 DUW2001 OFF ON OFF KDU127161/2 R4C TU8X169165 20110702 47C Active*
SMN ProductNr Rev Name Date SerialNr
0 SXK1098604/1 * Subrack Radio Subrack
SMN APN PORT BOARD FAULT OPER MAINT PRODUCT NR REV SERIAL DATE TEMP AuxPIU Cells
0 1 port_0_dev_5 RRUS01B1 OFF ON OFF KRC11876/1 R1C C824347865 20110310 46.1 1-1/RRUW-1 S1C1 S1C2
0 1 port_1_dev_6 RRUS01B1 OFF ON OFF KRC11876/1 R1C CC45813424 20110710 52.6 2-1/RRUW-1 S2C1 S2C2
SMN APN PORT BOARD AuxPIU TX1(W/dBm) TX2(W/dBm) VSWR1 (RL1) VSWR2 (RL2) Cells
0 1 port_0_dev_5 RRUS01B1 1-1/RRUW-1 21.3 (43.3) N/A 1.15 (23.2) N/A S1C1 S1C2
0 1 port_1_dev_6 RRUS01B1 2-1/RRUW-1 30.5 (44.8) N/A 1.08 (28.6) N/A S2C1 S2C2
#10
CABX command output is different in my Node B.pls suggest accurate command for it if any.
