We got multivendor in our network
HOSR from Ericsson to Nokia works well. But Nokia to Ericsson is very poor.
Any suggestions
This post is transcribed from the LTE Whatsapp group
Any suggestions
Handover through X2 or S1 ?
Handover is through X2
Does S1 is OK towards E//?
Ericsson to Nokia both work well. But Nokia to Ericsson nothing…more are on X2…s1 attempts are very low
Check x2 IP retrievals . check IP of enodeb in ipno and lnaj missmatch
Check the IP configs; I think IPconfig results in zero succes, is it the case ?
Did u check events’ thresholds ?
Not all are failed
Some successes are also there
Failures most come from intra or inter frequency
Try to switch to s1 all att
Are HO thresholds on both vendors same or different?
Handovers are Intra freq
m8000c37 and c38 for IP x2 retr
Thank you. …
