Dear expert
We are having 9MHz in 1800, it is possible to implement LTE in 9Mhz, if Yes please suggest how to RND an d RNP for Same ( if some Doc than please do share)
Thanks in advance.
Dear expert
Thanks in advance.
Hello, the solution is very simple:
Use the RB for 9 MHz, and the central on the middle.
It will work nice and easy.
I have made this on 4.8 MHz and also with 3 MHz.
And You can use blanking features in UL if you want: with that, the scheduler will exclude from grants outermost PRBs.
If the vendor is huawei, you can you the feature compact bandwidth
Thanks for feedback,
yes the vendor is Huawei, Thanks for the answer
