Why the name β802.11β?
The name 802.11 comes from how the IEEE (Institute of Electrical and Electronics Engineers) organizes its networking standards.
What does β802β mean?
β802β is the IEEE working group responsible for local area networks (LANs).
It was created in 1980, in the 2nd month (February).
Thatβs why the number is:
80 (year) + 2 (month) = 802
Within this group, there are several subgroups:
- 802.1 β Bridging/Switching
- 802.3 β Ethernet
- 802.15 β Bluetooth / PAN
- 802.16 β WiMAX
- 802.11 β Wireless LAN (Wi-Fi)
In other words: the number is not random β it identifies the committee responsible for LAN technologies.
And what about β.11β?
Inside the 802 group, each project receives a specific number.
The number 11 was assigned to the wireless LAN (WLAN) standard.
Thatβs why everything related to Wi-Fi is formally named IEEE 802.11.
Why not another number, like 802.14 or 804.xx?
Because Wi-Fi was created inside the 802 working group, which already existed since 1980.
So, the number is not chosen arbitrarily β it depends on the technical committee where the project originated.
If Wi-Fi had been developed in a different committee, it would have received a completely different number.
But since all LAN technologies (wired and wireless) belong to Group 802, the standard naturally became:
- 802 β LAN working group
- .11 β specific wireless LAN project
Simple as that.
Where does the name βWi-Fiβ come from?
Despite popular belief, Wi-Fi does NOT mean βWireless Fidelity.β
That phrase was used only briefly as a marketing slogan.
The name βWi-Fiβ was created by the branding agency Interbrand to be:
- short
- easy to remember
- reminiscent of βHi-Fiβ (high fidelity audio)
The brand is managed by the Wi-Fi Alliance, which certifies Wi-Fi devices.
Meanwhile:
- Wi-Fi β commercial name
- 802.11 β technical name of the standard
Wi-Fi Standards Timeline (IEEE 802.11)
1997 β 802.11 (original)
- First Wi-Fi standard ever.
- Maximum speed: 2 Mbps.
- Very limited, now fully obsolete.
1999 β 802.11b and 802.11a
802.11b
- The first version to make Wi-Fi truly popular.
- 11 Mbps β 2.4 GHz
- Affordable, good range.
802.11a
- 54 Mbps β 5 GHz
- Faster but with shorter range.
- More expensive at the time, used mainly in enterprise.
2003 β 802.11g
2009 β 802.11n (Wi-Fi 4)
2013 β 802.11ac (Wi-Fi 5)
2019 β 802.11ax (Wi-Fi 6 / Wi-Fi 6E)
Wi-Fi 6: 2.4 + 5 GHz
Wi-Fi 6E: 2.4 + 5 + 6 GHz
Key features:
- OFDMA
- Uplink MU-MIMO
- Better efficiency in dense environments
- Access to the brand-new 6 GHz band
Max theoretical speed: 9.6 Gbps.
2024/2025 β 802.11be (Wi-Fi 7)
The most advanced Wi-Fi ever created.
Main improvements:
- 320 MHz channels
- 16Γ16 MIMO
- 4096-QAM
- Multi-Link Operation (MLO) β uses multiple bands at once
- Extremely low latency
Speeds: 30β40 Gbps.
One-sentence summary
Wi-Fi is the commercial name; the actual standard is always IEEE 802.11 + a revision (a, b, g, n, ac, ax, be).
