What Is VoLTE and Why Do Calls Sound Better on It?
If you have ever noticed that some calls sound clearer than others, or seen a “VoLTE” or “HD” icon on your phone during a call, this post explains what it means.
What is VoLTE?
VoLTE stands for Voice over LTE. Instead of using the older 2G/3G network for calls, your phone sends voice as data over the 4G LTE network. In simple words, your call travels the same way your internet data does, but with priority.
Why do calls sound better on VoLTE?
1. Wider audio range (HD Voice)
Traditional calls on 2G/3G carry a narrow range of sound frequencies, which is why voices often sound flat or “tinny.” VoLTE typically uses wideband codecs such as AMR-WB, which capture a much wider range. Voices sound fuller and more natural, and it is easier to understand the other person.
2. Less background noise
VoLTE networks generally handle noise and signal quality better, so calls are less likely to have hissing, crackling, or sudden muffled sections.
3. Faster call connection
On phones without VoLTE, the device often has to drop from 4G to 3G or 2G before placing a call. This is called a circuit-switched fallback. With VoLTE, the phone stays on 4G, so calls usually connect within a couple of seconds.
4. Voice and data at the same time
Because you stay on 4G, you can browse, stream, or use maps during a call without your internet slowing down or stopping.
5. Priority for voice traffic
The network gives call traffic a dedicated, high-priority path, so your voice is less affected by other users downloading or streaming nearby.
What do you need to use VoLTE?
  • A phone that supports VoLTE
  • A network and SIM that support VoLTE
  • VoLTE enabled in your settings (in many phones it is on by default)
  • Decent 4G or 5G coverage in your area
VoLTE gives clearer, more natural-sounding calls, faster connections, and the ability to use data while talking. It is one of the biggest everyday improvements 4G brought to voice calling.
