Hello All.
What is the electric field produced by 5G Mobile Phone?
Hello All.
Hi,
well, I would go in following direction.
5G UE TX power, usually you can consider 23dBm (non HP UE), then you consider antenna gain which for Sub7GHz would be 0-2dBi, and this gives you EIRP. EIRP can directly translate into an electric field strength.
