What could be issue of low TCP throughput in DL 5G SA?
Check bler, collect trace and compare at wireshark expert view, select packts per second versus time and filter tcp.streams.
If I were you, i’d compare both cell config once again.
And focus on TX backhaul!
If both cells have the exact same config & setup, results are strange.
HARQ retx does not explain much lower cell2 TCP Tput.
For OTA, dramatic RF condition change could cause degrade when testing cell2 TCP.
So I would double check if UL Tput (MAC/RLC/PDCP) show such discrepancies.
And conduct longer test to check the distribution (SNR/SINR, BLER, MCS, RB utilization) from both UE log and DU counters.
