System Time in Ericsson BSC
Hi Team,
Requesting to share MML commands to see system time in BSC. And if the system time is wrong, how do we correct it? Please let me know.
Hi, @Sooraj,
CP
CACLP:ALL;
CACLS:DATE=date,TIME=time[,DAY=day][,SEC=sec];
Example 1
CACLS:DATE=070530,TIME=0812;
The program clock is set to 08:12:00 on 30 May 2007, and the weekday will be set to Wednesday. When setting the clock, specify the time to the current time plus some minute. When this time is reached, give the execution order.
Example 2
CACLS:DATE=070530,TIME=0812,SEC=30;
The program clock is set to 08:12:30 on 30 May 2007, and the weekday will be set to Wednesday. When setting the clock, specify the time to the current time plus some minute or seconds. When this time is reached, give the execution order.
Example 3
CACLS:DATE=070530,TIME=1812,DAY=WED;
The program clock is set to 18:12:00 on 30 May 2007, and the weekday is set to Wednesday. When setting the clock, specify the time to the current time plus some minute. When this time is reached, give the execution order.
APG
Example: 1
Read the time from the AP cluster.
date
Tue Jun 26 01:16:42 CEST 2012
Example: 2
Get the help printout.
date -h
usage: date [-s DATE][-u][“+FORMAT”]
date -h
-s DATE Set the system time and hw clock in both nodes.
-u Read or set the time in UTC format.
“+FORMAT” Display the time in both nodes in the given FORMAT.
-h Display this help.
The command reads the system time from both nodes or sets the system time
and hardware clock. The command must be executed from the active node.
Example: 3
Set the system clock and hardware clock in the AP cluster.
date -s “2012-06-25 13:32:00”
Mon Jun 25 13:32:00 CEST 2012
Example: 4
Read time from the AP cluster. Format the output according to the format string.
date “+%F %T”
2012-06-25 13:35:53
Example: 5
Set the system clock and hardware clock in the AP cluster and format the output.
date -s “2012-08-06 16:30:00” “+%F %T”
2012-08-06 16:30:00
Thank you so much.
