Hi,
Please suggest way to improve NSA_LTE_AFR%.
Failure happening during preparation with 20% fail rate.
Pre check-
NR & LTE cells are defined at both ends.
Hi,
Pre check-
I believe this video can help, as failures happening in LTE.
It is for 4G LTE VoLTE RRC / AFR /Accessibility KPI Optimization with Parameter Tuning.
Youtube: 4G LTE VoLTE RRC/AFR/Accessibility KPI Optimization with Parameter Tuning - YouTube
RRC Success Rate is the first major KPI and it is part of LTE/ VoLTE Accessibility.
In this video, you will learn, how RRC failures comes in network and what are the parameters to reduce it.
