One question regarding SFN in MIB
MSB - 6bits LSB - 4 bits
1023 - 0011 1111 1111
0011 1111 → MSB
1111 → LSB
Remain 4 bits are derived from PBCH payload → i didn’t understood this point.
Why 4 bits are send separately?
And when it says PBCH payload, what does that mean?
MIB also goes through PBCH only ?
Also, why didn’t they make 6 or 5bits in LSB to send through PBCH payload?
It will reduce the MIB size further down.
susbose10:
Pbch load means th3 content of PBCH.
MIB is layer 3 content of layer 1 PBCH.
susbose10:
Because MIB in 5G is 24 bits, are needed for something else cannot be occupied by 5-6 bits of LSB of SFN.
4 is enough.
O.B
October 19, 2022, 11:55pm
3
MIB is L3 generated by CU and PBCH is L1 generated by DU
Using this technique, CU will generate MIB less frequent since its contents will not change every frame
