You can keep 750 ms if it’s for qci 6 to 9.
Yes it is. NSA bearer but um rlc and pdcp discard timer infinity.
Is it at LTE end or 5G end setting for pdcp profile?
It is at 5G end.
Ok, um used for VoLTE In LTE. Is it VoNR specific case?
Actually it is not, for data but um.
Need to check why um for data used here.
Give me sometime.
It is changed to um for some testing purpose just.
Hi Experts. In Huawei this parameter DlPdcpDiscardTimer is set 150ms instead of DiscardTimer_Infinity.
What is the impact of this?
What is the QCI?
Hi, QCI=9.
You can check for other QCI.
We use only QCI=9.
I mean this command is applicable for each QCI.
Each QCI may have its own value.
Here is example of this command result.
each QCI is configured with each PDCP parameter group.
So, the DL PDCP discard timer is different for each QCI.
Dear friends can you help me to know the pdcp discard timer name for Ericsson Ran
better using qci 3gpp standart table if your bugdet of latency you can achive
Hi experts, what will be the impact on KQI when we change PDCP discard timer from infinity to 750ms?
I got good results with 750ms, but UL packet loss rate increased to 20%, before it was infinity and 5% ul packet loss. All other KPIs improved…
