Indeed.
In some cases repeaters were the cause of degradation.
I remind you once again that the RTWP degradation I mentioned concerns U900 cells only.
Indeed.
Yes, It is possible that external interference is affecting only one particular band.
It may not necessarily be repeaters. It could be a new TV broadcast [just a example] which is using some portion of U900. We faced this issue in our network.
The only way to find the source is RF scan using field measurements and locate it.
Also try to Plot the RTWP hourly pattern, If it improves in some hours?
Iโm talking about a real case which was solved by disabling repeater installed on site.
Surely with value it is either related to the Hardware or configuration.
Check if is it the same antenna model, radio unitโฆ
Have you already checked the overshooting part?
