Vicky
January 17, 2021, 3:00am
1
Hi All,
I have to do an audit in the network level to check all license expired date.
For example, using command invl basic
And i get list with ValidFrom and ValidUntil.
Apart from MO bacth process, does we have any other way? Like in ENM? Or any specific MO? Vendor is Ericsson.
Did you check in FeatureState MO?
Vicky
March 18, 2021, 5:27pm
3
Yes, I checked some MOs:
FeatureState
FeatureKey
CapacityKey
Bbut license expiry information are missing…
Hmm. Then Mobatch can help mate, but it would take some time if you have more number of nodes.
Vicky
March 18, 2021, 5:29pm
5
Yeah, Mobach is time taking process.
That’s why i am looking for some other workaround.
Anyhow, Thanks!
I prefer doing this kind of stuff with MO Batch as it is real time and accurate.
But if you want to avoid, please check SMO (Software Management Organizer ) in Ericsson OSS you may find the expiration date of each feature once you export the XML.
Did you try with ENM CLI?
You can do everything in ENM CLI.
You have to use cmedit
You can use also SHM (instead of SMO).
There is some instrcutions for Boda users:
These are steps to get Ericsson Inventory (INV) Data to use with Boda.
Via OSS RC
2G BTS Inventory
Exporting 2G BTS Inventory via GUI
TBD
Exporting 2G BTS Inventory via CLI
Log in into “Ericsson OSS” via Citrix.
Launch > Applications > Utilities > Terminal
Run BSM command:
bsm_hw_export -H > YourFileName.txt
The resulting file will be exported to the directory where you did run the command.
TIP: Option -H will add Column Header, and also print the Date of Export in the file. Recommen…
Another option is to use cmedit get * featurestate.licensestate
Do it via ENM, it’s very easy:
ENM -> SHM -> Licence Administration -> select Nodes -> Export
Vicky
March 18, 2021, 5:56pm
10
