Mobile RF power measurements: dB, dBm and the reference plane
Disclosure: I authored the paid English Udemy course linked below. Here is a power-measurement example where the arithmetic is easy, but comparing two valid results can still produce a wrong diagnosis.
Worked example: a 1.5 dB difference without a DUT change
A DUT delivers 23 dBm at its output connector. The cable to the analyzer has 1.5 dB loss at the test frequency. For this example, assume the same signal and power-measurement definition, with other path effects omitted.
Result Correction state Reference plane
21.5 dBm External path-loss correction off Analyzer input
23.0 dBm Cable-loss compensation already applied DUT output connector
24.5 dBm Another 1.5 dB added manually to the corrected 23.0 dBm result Incorrect double correction
The first two values can describe the same DUT output. Their difference alone does not demonstrate a transmitter fault. The third value is an interpretation error, not a power improvement.
Before comparing two instruments or reports, check:
  • Reference plane and correction state: which cable/attenuator losses are included, at what frequency, and whether an instrument offset, correction table or external gain setting already accounts for them. Check the instrument’s sign convention.
  • Measurement definition: channel/integration bandwidth, detector or averaging method, burst timing/gating and the DUT operating condition must be comparable.
  • Uncertainty: cable-loss uncertainty, connector repeatability and mismatch still matter, especially near a pass/fail limit. Applying a nominal correction does not remove measurement uncertainty.
dBm is a power level relative to 1 mW; dB expresses a ratio such as gain or loss. In a technical interview, explaining why two readings differ, and which setting would confirm that explanation, demonstrates more than presenting the subtraction alone.
The course connects these habits with RF power, impedance/S-parameters, noise/nonlinearity, mobile Tx/Rx tests and OTA measurement concepts. Mobile RF Fundamentals: English curriculum and preview on Udemy (paid)
Reference for external gain/loss compensation: Keysight X-Series Signal Analyzers, Getting Started and Troubleshooting Guide, page 21.
