Hi,
Any related parameter in Huawei for LTE UL throughput enhancement?
Preallocation and smartpreallocations switches are set to OFF.
PAMC and UL Comp.
PAMC:
Family: CellAlgoSwitch
Parameter: UlSchExtSwitch=UlPAMCSwitch-1
Got good improvement with PAMC.
Recommended.
Anyone did Enhanced UL Comp trial?
I think this one need strong X2 latency,
Yes, it does.
I implemented UL comp in 2017 in Nokia.
Is Enhanced UL comp is same or different?
Normal UL comp will work on the same eNB, co-site cells.
Enhanced UL comp will work with neighbors eNB. So it has strong latency requirements in X2 interface.
Any gain in UL throughput?
Should have.
On the networks I have worked, minimum latency requirement is not reached.
I believe it will need time and phase synchronization between the eNodeBs to be functional.
