LTE and 5G call-process analysis: radio, registration and session state
Disclosure: I created the paid English Udemy course linked at the end. This example shows why a device trace needs separate radio, registration and session-state conclusions.
Worked trace: does an RRC release mean a fresh attach?
Consider an ordinary LTE/EPC connected-to-idle sequence, without the suspend/resume variants:
Trace evidence What to establish before drawing a conclusion
Traffic is active, followed by an S1/RRC connection release The access/signaling connection has been released. Check the NAS registration and EPS bearer context separately.
Later, RRC establishment and a NAS Service Request appear, followed by successful bearer setup The trace shows a service-request path. Do not label it a new attach unless an Attach procedure is actually present.
Application traffic or an IMS call still fails Examine the relevant PDN/bearer, IP and SIP/media evidence; restored radio access alone does not establish application recovery.
The common misreading is to call the first event “the UE detached” and the second “the UE reattached.” EPS registration and connection management describe different states: a UE can remain EMM-REGISTERED while ECM-IDLE. A normal access release therefore needs a different explanation from NAS deregistration.
To make the distinction defensible, retain a short evidence set:
  1. Access mode and the precise release/re-establishment messages, with timestamps.
  2. NAS registration state and any Detach or bearer deactivation procedure, alongside the retained PDN/EPS bearer context and IP address.
  3. For an IMS service, registration validity and the relevant SIP dialog/media state, correlated to the same interval.
Missing messages in a partial capture are not proof that the corresponding procedure never occurred. State the capture boundary and the next observation needed.
This is an LTE/EPC example. Keep LTE/EPC, 5G NSA and 5G SA procedures distinct when applying the same evidence-based method; their state names and message sequences are not interchangeable.
My English course develops device-focused call-process analysis and technical-interview explanations. 5G/LTE Call Process: curriculum and preview on Udemy (paid)
Technical reference: 3GPP TS 23.401, sections 4.6.3 and 4.6.4, ETSI Release 18 edition.
