Dear Experts.
What logic can be the set if someone wants to build program which gives recommendation to optimize worst performing cells LTE/VoLTE?
Optimization recommendation for both self and nbr cells.
Dear Experts.
You should have three things combined in your program:
Set two thresholds
Tool is supposed to analyze three things
So you will have everything readily available for trouble shooting from physical design to parametric changes, and you can generate recommendations on basis of it.
You can also plot KPI deltas on map so it will immediately highlight whether issue is localized or distributed.
You can also compare your parametric audit with base line of parameters.
