Q. In the INVITE sent towards SCC-AS for SRVCC what is the Value set in the Request-URI inside this INVITE?
a) ATU-STI
b) MSISDN
c) STN-SR
d) IMSI
Check 🔎
Correct answer: Letter c. (or a *)
* please check this comment
When an INVITE is sent to the SCC-AS as part of the SRVCC (Single Radio Voice Call Continuity) procedure, the Request-URI is set to the STN-SR (Session Transfer Number for SRVCC).
- The STN-SR is a temporary routing number used to reach the target MSC in the CS domain.
- It is allocated by the MME and delivered via SIP to the IMS core.
- The SCC-AS identifies the session transfer using this value and routes accordingly.
a) ATU-STI
→ Incorrect. The Access Transfer Update – Session Transfer Identifier is used in header fields but not in the Request-URI.
b) MSISDN
→ Incorrect. The MSISDN identifies the user, but SRVCC routing uses a temporary routing number.
c) STN-SR
→ Correct. STN-SR is placed in the Request-URI to route the INVITE to the correct CS domain node during SRVCC handover.
d) IMSI
→ Incorrect. The IMSI is not used in SIP signaling; it is an internal identifier for mobile networks.
- “Use the reference coupon below for a significant discount on the course.”
