High PRB Usage Solutions
Discussion of High PRB Utilization is a function to User Throughput and Avg connected users.
Optimization is ofloading users to 3G Layers or addition of another LTE Layer
What do you mean? Im asking about the functionality of thr switch
Much thanks!!
@Ghazy_Mohammed any help please?
could you please elaborate more about that parameter and how it works?
if you can’t add new carrier and then add new sites
anyway many way to improve your capacity with improve your RF quality, then your Spectral more efficient . back to basic theory Shannon–Hartley theorem
what is mml command for changing these parameters?
@Cesar_Nunes what is the mml commands for these parameters
These parameters are in CELLPDCCHALGO MO.
So, create your MML accordingly.
You can conversion this cell to 4x4 MIMO
In ZTE 4G I’ve a lot of cells (1 carrier only) which the PRB Usage is >85% and at these hours the RRC connect user is high and make DL Throughput is slow.
Do you have any optimizatiion suggestion to try to improve the Throughput?
Best Regards,
