Reasons…
Radio and Transmission Part…
Poor Signal Strength/Quality :
- Weak target cell signal (RSRP/RSRQ) due to distance or obstacles.
- Incorrect handover thresholds (e.g., hysteresis, time-to-trigger (TTT) settings).
Network Planning Gaps📊:
- Coverage holes or overlapping cells due to poor RF planning.
Congestion :
- Target cell resource congestion (lack of PRBs, channels, or processing capacity).
Configuration Issues👨💻:
- Incorrect neighbor cell lists (missing or outdated entries).
- Faulty X2/S1 interfaces between eNodeBs or core network elements.
Mobility Challenges🚀:
- High speed scenarios causing rapid cell changes.
- Radio link failure before handover completion.
Core Part…
Hardware/Software Faults:electric_plug::
- eNodeB or UE hardware malfunctions.
- Software bugs in eNodeB, MME, or UE firmware.
Solutions…
Network Parameter Optimization:
Fine tune handover parameters such as:
- Event A3 offset (determines when handover is triggered)
- Time-to-trigger (TTT) values (prevents ping-pong handovers)
- Hysteresis margins (provides stability in decision making)
Configuration and Synchronization Improvements:
- Enable Automatic Neighbor Relations (ANR) to update neighbor lists dynamically.
- Validate X2/S1 interface health and redundancy.
Congestion Management:
- Expand capacity e.g., carrier aggregation and MIMO.
- Improve network coverage by:
- Adjusting antenna tilts and azimuths.
- Optimizing power levels.
- Adding small cells in problem areas.
- Use admission control to prioritize handover requests.
- Implement smart load balancing through:
- Dynamic resource allocation.
- Traffic steering.
- Cell breathing techniques.
Network Testing and Monitoring:
- Conduct drive tests and use RF planning tools to identify coverage gaps.
- Monitor Key Performance Indicators (KPIs) like Handover Success Rate (HOSR) and RLF counters.
Core Network Enhancements:
- Ensure MME robustness with failover mechanisms.
- Optimize authentication/authorization processes to reduce latency.
Hardware/Software Maintenance:
- Regular firmware updates for eNodeBs and UEs.
- Proactive hardware audits and redundancy checks.
These are reasons and solutions for handover failure in general in the generations not for 4G only, I just focused on it as an example. but some techniques depends on specific system.
LinkedIn:
