Hello Experts,
I am facing a very unique and challenging scenario related to a regional 4G LTE network blackout and session handling, and I would love to understand the underlying core network behavior and if there’s any technical workaround.
Device & Network Setup:
* Device: Vortex C6 MiFi Portable Router (OEM: Shenzhen WeWine Wireless Co., Ltd). It’s a simless/cloud-SIM-based 4G LTE-only device.
* Network Context: Yemen 4G. There is a total, comprehensive 4G LTE regional blackout enforced on an entire province (all cellular networks have disabled 4G authentication/access locally within this region). The nearest province where 4G is fully functional is about 150 kilometers away.
The Phenomenon:
If I power ON the MiFi router in the active 4G province (150 km away) and establish a successful connection, and then travel into the restricted/blackout province while keeping the router continuously powered ON (active battery/power session), the 4G internet continues to work flawlessly inside the restricted zone!
It seems the device holds onto the active session ID, and the local towers in the restricted zone somehow route the data packets through a handoff/handover mechanism without terminating the active connection.
The Problem:
The moment the router loses power, turns off, or the battery dies inside the restricted province, the active session is completely destroyed. Upon reboot, the router attempts a fresh registration/authentication request with the local towers, which is instantly rejected due to the regional geofencing/blackout policy. It completely loses the 4G signal.
My Questions to the Forum:
1. From an LTE core network architecture perspective (MME, HSS/HLR, PGW), what exactly keeps the data session alive over a 150 km transit into a blackout zone? Is it a delayed VLR/HLR location update or a specific session handover behavior?
2. Since physical long-range antennas (MIMO/Yagi) are useless over a 150 km distance, is there any known AT-command modification or custom firmware trick for Qualcomm-based MiFi routers to spoof/clone a previously successful session ID (Session ID injection) or force a fake registration bypass upon reboot?
Thank you in advance for your technical insights!
